Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 5 speed trans problems
Old 10-25-2012, 05:16 PM   #2
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
What I Drive: 13&14 SE hatch
Points 2,703, Level 31
Points: 2,703, Level: 31 Points: 2,703, Level: 31 Points: 2,703, Level: 31
Level Up 69% Completed
Level up: 69% Level up: 69% Level up: 69%
FF Reputation: 12 Mike_Mac Great Standing Member
Buy-Sell-Trade Rating: (8)
i think its a slave, master cyl or the clutch line. hopefully for you is the master cyl. look to see if its wet (greeen plastic thing by the pedal.) if by pumping the clutch 5-10 times it solves the issue i think your getting air into the system.
also the fluid could need changing and when cold it can make it hard to get into gear, but i have never had it grind.
i would check the hydralics, bleed the clutch, ect. then look at the fluid level if you don't know how old it is you might as well change it.
Mike_Mac is offline
