Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - A/C problems
Thread: A/C problems
Old 10-25-2012, 05:12 PM   #14
lhcaz
Fan#: 105296
What I Drive: race red
FF Reputation: 0 lhcaz Newbie
I also had the same a/c issues and way more so after 8 months of getting nowhere I took matters into my own hands and did some research.
At issue is the a/c condenser its behind the shutters that cover the radiator and they open when the car engine needs to cool down.aka the thermostat opens the fan turns on the shutters open. There is more to the system but for the most part that’s the science behind how it works. There is some air flow when the shutters are closed but simply not enough for any a/c system to work properly.
The main issue is the fords design, when we had cool temps like 85 to 95 degrees,
the car did not need as much fan time so the a/c condenser gets little or no are flow. Even with the a/c on max the shutters are closed, Thus giving us a cabin temp of 75 to 80 degrees (way to hot).
The a/c temp at the dash (vents) averaged 45 to 60 degrees on max but the temps were up and down as the shutters opened and closed over and over.
We live in the Mohave Desert so it gets hot like 100 to 115 even 125 degrees when it was that hot the car is Needing more fan time so the fan runs more so the a/c seemed to work.
Why?
Because the a/c condenser was getting max air flow.
The flaw is Fords shutter system having the a/c condenser behind the shutters;thus no air flow.
After consulting an attorney I was told I could use the Lemon law because of the few months i owned the car, low miles and a multitude of required documented trips to the dealer for the same a/c issue.
He also told me the focus is selling like hot cakes and ford will never
Admit to a design flaw and or an a/c issue. so no full refund.
A factory Ford rep. also told me there was nothing wrong with the car.
So I traded my new 2012 ford focus in on a new 2012 import.
The a/c blows 29 degrees all the time.
I don't feel its fair to list the brand i now own but there truck line
did pull the space shuttle.
FORD
I have never been so let down in my life with a US made car.
lhcaz is offline
