Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - New here 2003 zx3 5 speed long intro :)
Old 10-25-2012, 05:12 PM   #24
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 33,119, Level 100
Points: 33,119, Level: 100 Points: 33,119, Level: 100 Points: 33,119, Level: 100
Forum Activity 59%
Activity: 59% Activity: 59% Activity: 59%
Well if it can't be turned around, then maybe that tube was put in backwards. Did you look at the holes in the MAF as I described to see if it was turned around the right way?
If it's pointed the right way, then it is not the problem unless the wiring is damaged somehow. From what you described, it could be the TPS, you'll have to get out your multi-meter and test it to see if the resistance is correct.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
