Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Any interest in headlight modifications?
Old 10-25-2012, 11:49 AM   #157
calebstubstad
Chef Boyardee
Fan#: 103240
What I Drive: 2003 Screaming Yellow SVT EAP
Points 2,926, Level 33
Points: 2,926, Level: 33 Points: 2,926, Level: 33 Points: 2,926, Level: 33
Level Up 18% Completed
FF Reputation: 4 calebstubstad Good Standing Member
no, the "threaded end" sticks through the hole that the halogen bulb did, its like a perfect fit, then theres a silicone right you put on, nut, then lock nut that twist onto the threads of the projector. it just attaches perfectly to the original housing, and then you can either drill a small hole for the solenoid (high beam control) wires, or just run them through the back as well. and if it's done right, you should barely have to, if at all, aim the lights again, and they will be stuck right in exactly how the halogen bulb was. the morimoto minis from TRS are a perfect fit for the focus, no doubt
Rally Revolution #43
[HOONIGAN]
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
