Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Why you should retrofit your lights
Old 10-25-2012, 09:38 AM   #57
LikwidZX5
LikwidZX5's Avatar
Fan#: 34180
What I Drive: 2015 Oxford White Fiesta ST
Points 2,173, Level 28
Points: 2,173, Level: 28 Points: 2,173, Level: 28 Points: 2,173, Level: 28
Level Up 16% Completed
FF Reputation: 4 LikwidZX5 Good Standing Member
Originally Posted by A7xschecter6661 View Post
Did you put the big ones in? If so that's your problem.
I made the driver side hole big, and the passenger smaller, so I put the big one on the driver side which aimed it down and the passenger one worked and aimed fine.
Swapped out the washer and put it back in and it was adjusted so high (from me having it aimed to make up for the stupid washer) that I had to lower it
Now my lights are officially amazing
And using the windshield urethane is awesome! I ran the heat gun around the assembly 3 or 4 times.
Pried the lens with a screw driver in one spot and pulled it off by hand and it goes back on nice and seals good.
I can have the grille and headlight off the car, unplug the bulbs, bring it inside, heat gun it and get the lens off within 10 minutes, it rocks!
Yeah, I used the big ones. My train of thought was something along the lines of, "the big washers have more rubber which should be better against vibration"
older: 2002 ZX5//old: 2006 ST//current: 2015 FiST
LikwidZX5 is online now
