Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Why you should retrofit your lights
Old 10-25-2012, 05:38 AM   #55
LikwidZX5
LikwidZX5's Avatar
Fan#: 34180
What I Drive: 2015 Oxford White Fiesta ST
Points 2,173, Level 28
Points: 2,173, Level: 28 Points: 2,173, Level: 28 Points: 2,173, Level: 28
Level Up 16% Completed
FF Reputation: 4 LikwidZX5 Good Standing Member
Originally Posted by A7xschecter6661 View Post
All done, ripped my driver headlight apart again and fixed the issue.
The projectors come with 2 different rubber seals for the back of the projector bowl against the reflector housing.
The driver side I rounded out a lot and used the big one, the passenger not so much and used the small one.
This caused my driver side to be lower than my passenger, even when it was adjuster higher.
Ripped it apart again and swapped the washer and now it works beautiful.
I will get better pictures when its not so foggy out!
I wondered if those rubber washers could've been the culprit. Just been too busy to open them again. I know what I'll be doing once the semester ends
older: 2002 ZX5//old: 2006 ST//current: 2015 FiST
LikwidZX5 is online now
