Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Any interest in headlight modifications?
Old 10-24-2012, 07:39 PM   #155
craigsfocus
craigsfocus's Avatar
Fan#: 97985
What I Drive: 2012 Race Red SE
Points 3,162, Level 34
Points: 3,162, Level: 34 Points: 3,162, Level: 34 Points: 3,162, Level: 34
Level Up 75% Completed
FF Reputation: 6 craigsfocus Good Standing Member
Originally Posted by -Shin- View Post
Amazing result Craig, I'm seriously thinking on this work.
You used Morimoto Mini because of size or you think a larger model will fit? There is also a problem in lenght?
I used the Morimoto Mini kit because it offered relatively easy installation because of the threaded end. Its was also a size I was comfortable with as I was traveling down a dark untraveled road with this project. I think there is about an inch of clearance from the lens to the lens on the projector. The bigger projectors will not work unless you plan on cutting into the reflectors.
The Morimoto Mini kit also offered a great value. I wanted to keep the cost down without sacrificing quality. That makes this kit an affordable alternative to the Factory Projector lights for now.
2012 Ford Focus SE Hatchback Race Red. 203A Spec. Window Tint. K&N Typhoon CAI. FSWerks Race Exhaust. Weathertech Digital Fit Floormats. HIDs with Projectors. Build Date: 2/14/2012
Active Duty US Army. MOS 91E (Machinist). OEF Vet.
craigsfocus is offline
