Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Went from This Key fob to....that
Old 10-24-2012, 04:57 PM   #3
Incognito27's Avatar
Fan#: 34939
What I Drive: 2003 Ford Focus ZX5 Premium - White
FF Reputation: 3 Incognito27 Good Standing Member
pull apart the original key fob as if you would change the battery , pull out the circuit board , and put it in the new fob and transfer the battery . Taking the transponder out is a little more tricky as you need to carefully pull the rubber/plastic carrier in key itself to get the transponder out . once you do its simply tape it inside the new FOB , and thats it.
Incognito27 is offline
