Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Is it possible to replace BT mic?
Old 10-24-2012, 03:19 PM   #3
copernicium112
Fan#: 87742
What I Drive: 2012 Sonic Blue Ti Sedan
Points 1,565, Level 22
Points: 1,565, Level: 22 Points: 1,565, Level: 22 Points: 1,565, Level: 22
Level Up 65% Completed
FF Reputation: 4 copernicium112 Good Standing Member
Originally Posted by Stryker412 View Post
I've heard since I got the car how bad my calls sound. I always chalked it up to it not being very good with noise cancelling. My wife borrowed my car a few weeks ago and called me. I completely forgot where she was calling me from and I kept asking her if she had the window open or if the air was on. The sound is horrendous.
Is there a way to replace the mic? It's really bad.
When I got my car my wife had no problem understanding me when I called her from the car. After the 3.0.2 update she says all she can hear is background noise and can barely understand me. I don't think the mic went bad. If it did, it is awfully coincidental that it would go bad immediately after installing 3.0.2. Some over at SMR say it can be made better by toying with the volume.
"I believe if you read some of the other threads you will find out you need to turn your volume up in the car. I found this out by trial and error with my friend. When talking BT to BT it really gets interesting when the other caller (Prius BT) insists it's your car. Just try increasing your volume control and see if that doesn't work."
And this guy had a good way to test it out:
"I actually called my work voicemail on the way in this morning. I had kept talking while turning the volume up, recording as I spoke. When I listened to the voicemail, it had started out with the open window clutter, and slowly cleared as I was adjusting the volume. Thanks for the help. Hopefully this was the cause. Ford should document that in the manual if it was."
I haven't tried this out yet so I can't speak from experience but just putting it out there in case you want to give it a try before looking into mic replacement. Can't hurt I guess.
.......here's a lockpick. It might come in handy if you, the master of unlocking, take it with you.
copernicium112 is offline
