Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Why you should retrofit your lights
Old 10-24-2012, 06:12 AM   #47
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
Points 4,931, Level 44
Points: 4,931, Level: 44 Points: 4,931, Level: 44 Points: 4,931, Level: 44
Level Up 91% Completed
FF Reputation: 5 DarderSauce Good Standing Member
Going to get this going too.
shield by DarderSauce, on Flickr
Result when light is off:
result by DarderSauce, on Flickr
Only Downside: You can see the solenoid and spring at the right angle.
solenoid by DarderSauce, on Flickr
But I figured that wouldn't be so bad.
What EXACTLY is it that makes the solenoid stick? Does it stick because it isn't smooth enough?
I have a friend that is an engineer and he works a lot with teflon coatings. I am going to see if he can hook me up and coat my solenoids. This would make it sooooooooo smooth I doubt I would have to worry about pre-install prep. But I think that might be a long shot so I will keep you updated.
If you can't wear it out, burn it off
DarderSauce is offline
