Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Why you should retrofit your lights
Old 10-23-2012, 09:52 PM   #46
A7xschecter6661's Avatar
Fan#: 98263
What I Drive: 2011 Focus SEL
FF Reputation: 2 A7xschecter6661 Good Standing Member
Originally Posted by DarderSauce View Post
Well I always take the advice of people that have walked the path before me so I think I will keep them. +1 for the linkage, always helpful!
No problem at all, mine have no issues unless I do a "high beam flash" then the driver side sometimes sticks.
Never the passenger though...
But yeah I wish I had a spare set, then I wouldn't have had to rush the install and wouldn't mind taking them out to adjust/fix anything in the future.
I want to take mine out and rotate the passenger projector a hair, and I think I found the problem with my driver side adjuster being so low.
The shield inside might have warped, or I didn't have it in the correct spot and when it raises, it hits the turn signal bowl. But the passenger side doesn't.
I will have to pull it apart, shove a screw driver in the turn signal bulb hole and try to pop it out of the way so it works correctly
A7xschecter6661 is offline
