Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Why you should retrofit your lights
Old 10-23-2012, 09:44 AM   #44
A7xschecter6661
A7xschecter6661's Avatar
Fan#: 98263
What I Drive: 2011 Focus SEL
FF Reputation: 2 A7xschecter6661 Good Standing Member
Originally Posted by DarderSauce View Post
Sure everyone has moments but continuously driving when visibility is shite isn't a moment, that's just called being a dip isht.
on a side note, just found me a driver side SES headlight so I am going to order my kit for das retro!!! Once I am done with that I am putting my other housings with the lamin-x tint and the PIAA bulbs up for sale.
If I were you I'd keep them.
In case something ever goes wrong and you have to reopen the lights, you have spares so you can take your time.
If you are getting the morimoto mini h1s make sure you do the pre install preparation which involves taking them apart, and sanding down the plunger so it never sticks.
Mine worked flawlessly out of the headlight, but now (it only happens when I am showing my lights off against a wall when they first warm up) if I pull the light switch back to flash the high beams, my driver side one stays engaged in high beam mode. Eventually switching back and forth makes it raise the shield again. I took them apart, and lubed them up but I did not sand them down.
Now I wish I did.
http://www.hidplanet.com/forums/show...moto-Mini-Tips
A7xschecter6661 is offline
