Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - smoking???
Thread: smoking???
Old 10-22-2012, 10:30 PM   #11
jfsiutza
jfsiutza's Avatar
Fan#: 97007
What I Drive: 2012 Ford Focus SE Hatch Tuxedo Blk
Points 1,545, Level 22
Points: 1,545, Level: 22 Points: 1,545, Level: 22 Points: 1,545, Level: 22
Level Up 45% Completed
FF Reputation: 1 jfsiutza Good Standing Member
Originally Posted by thehun View Post
How did you break in your engine? Did you baby it for xxxx miles?
If so...that is your problem.....you should not be losing that much oil if an engine is properly broken in
White Smoke usually means water.....hows your coolant level?
Also..go outside and check your tail pipe..if its oily...well time to take it in
i broke in the car doing street driving. i stayed away from the freeway if i could. by no means baby'n it. and there is no coolant consumption and no oil in the tail. just black soot.. lots of it.
im set on it being the pcv system thats not working too well
jfsiutza is offline
