Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2001 Ford Focus ZTS overheating
Old 10-22-2012, 12:27 AM   #10
BigMuthatrknG
BigMuthatrknG's Avatar
Fan#: 102123
What I Drive: 2001 Pitch Black ZX3
Points 668, Level 13
Points: 668, Level: 13 Points: 668, Level: 13 Points: 668, Level: 13
Level Up 36% Completed
FF Reputation: 1 BigMuthatrknG Good Standing Member
Originally Posted by amc49 View Post
If it seems to get somewhat better after overheating for a bit then high speed fan is kicking in after low did not when it should've. A/C not coming on says again low speed problem. Resistor or low speed relay problem. Resistor check is easy, if not melted then it's OK, relay harder, can stick occasionally and still test good. Best way there is buy a new one, not expensive.
where is that resistor located. I've been having the same problem except i took the connector off to test the ground and it was fine then plugged it back in and worked. drove a bit and then sat and idled for a while again and it started to overheat.
BigMuthatrknG is offline
