Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SPI Cooling Fan Resistor
Old 10-21-2012, 10:10 PM   #9
amc49
Fan#: 96610
Points 6,535, Level 52
Points: 6,535, Level: 52 Points: 6,535, Level: 52 Points: 6,535, Level: 52
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 79%
Activity: 79% Activity: 79% Activity: 79%
Perfect part throw it back in. The driver side and dogbone mounts can be pulled and look for torn rubber while flexing part. Pass side look for ruptured top or oil leaking, after that change it. You can put your hand around base rubber and grab firmly, if noise/vibration drop then rubber under aluminum ring is torn loose. Pull part in that case too and look.
amc49 is online now
