Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Intake manifold replace - hose help
Old 10-21-2012, 09:16 PM   #9
amc49
Fan#: 96610
Points 6,696, Level 53
Points: 6,696, Level: 53 Points: 6,696, Level: 53 Points: 6,696, Level: 53
Level Up 73% Completed
Forum Activity 100%
You guys are crazy............Push IN on the clip and the hose releases instantly, it's a quick release fitting. No need even to take it apart. When on assembly line the assembly tech simply pushes hose in and it locks. There are small teeth inside that grab hose, pushing ring in releases them.
You can find same type fitting at Home Depot in plumping department but Ford in its' infinite wisdom has made sure to use bastard one off size so not easily replaceable.
amc49 is offline
