Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 05 Focus fuel pump going out?
Old 10-21-2012, 05:16 PM   #15
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 33,344, Level 100
Points: 33,344, Level: 100 Points: 33,344, Level: 100 Points: 33,344, Level: 100
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
P0190 - Fuel Rail Pressure Sensor Circuit Malfunction (FRP) The comprehensive component monitor (CCM) monitors the FRP sensor to the PCM for VREF voltage. The test fails when the VREF voltage from the PCM drops to a voltage less than a minimum calibrated value.
Possible causes/solution
VREF open in harness.
VREF open in sensor.
VREF open in PCM.
Verify VREF voltage between 4.0 and 6.0V.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
