Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Cosworth IM install - what a NIGHTMARE
Old 10-21-2012, 02:14 PM   #2
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 9,030, Level 63
Points: 9,030, Level: 63 Points: 9,030, Level: 63 Points: 9,030, Level: 63
Level Up 94% Completed
FF Reputation: 17 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (11)
The little support bracket that comes with the intake should go on last. With it removed, it will give you enough clearance to get to the bolt. I had to use a 1/4" drive ratchet with a short handle and a deep socket. That gave me enough clearance to tighten the bolt up. This is definitely a bolt you need to get to from underneath the car.
The PS pressure sensor you can twist a little to give you the clearance to bolt the mani up.
Didn't you get a dipstick with your intake mani? Mine installed fairly easily. The dip stick bracket didn't line up perfectly though. I just had to bend the dip stick a little for it to line up.
FSWerks stg2 w/ water/meth; Cossie intake.
Massive Speed stg 2 cams in the works....
PSUrivie is offline
