Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 focus se converting rear drum to disc?
Old 10-20-2012, 11:54 AM   #6
Fraychild
Fraychild's Avatar
Fan#: 37309
What I Drive: 2012 Ford Focus SE
Points 62, Level 1
Points: 62, Level: 1 Points: 62, Level: 1 Points: 62, Level: 1
Level Up 24% Completed
FF Reputation: 2 Fraychild Good Standing Member
I think this set-up is definitely possible - time and research could help make it happen and less inexpensive
REPOST - maybe this might get some more attention:
REAR DISC BRAKE SET UP:
1 - Rotors - $80 (pair)
2/3 - Hubs Assemblies - $150 (pair)
4 - Backing Plates - $32 (pair)
5 - Backing Plate Bolts - $9 (for 8)
6 - Calipers - $170 (pair)
7 - Caliper Bleeders - $8 (pair)
8 - Caliper Hardware - $20 (pair)
9 - Caliper Support - $50 (pair)
10 - Caliper Support Bolts - $4 (for 8)
11- Brake Pads - $44 (set)
12 - Brake Springs - $16 (pair)
13 - ABS Sensor - $20 (pair) - if not compatible with current
14 - Brake Hoes - $22 (pair) - if not compatible with current
15/16 - Brake Tube and Line - $30 (set) if not compatible with current
So the total would be definitely be +/-$650 from Ford...
REAR DRUMS SET UP:
2012 Candy Red SE Manual... I smell serious trouble.
Fraychild is offline
