Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 HID Thread (Info Only No Arguing)
Old 10-20-2012, 06:56 AM   #275
Darketernal3's Avatar
Fan#: 98631
What I Drive: 2012 Ford Focus SE Sedan
Points 484, Level 9
Points: 484, Level: 9 Points: 484, Level: 9 Points: 484, Level: 9
Level Up 68% Completed
FF Reputation: 1 Darketernal3 Good Standing Member
Originally Posted by slow3v View Post
I just don't like the relays because of the extra wiring "mess."
That and if you tapped power from the driver side headlight wouldn't it show a pass. side error when using a relay kit?
I routed the wire in the front of the hood, along with the latch wire... Everything else is tucked either in the wheel well, or on the bottom side of the headlight assembly, pretty easy to do and not a mess, just takes a little time to organize.
As far as the relay/power issue... I should probably give it a simpler approach...
Think of each headlight as a lever that activates something.
In normal use, you throw the lever, it switches on a light attached to your battery.
With this relay setup, you throw the switch activate another switch that turns on a light attached to a different battery. The first light bulb that normally comes on... well it's been replaced with an iron ball....
Silver Ingot
203A Package
SE Sports Package
Two toned sports interior Stone/Black
Darketernal3 is offline
