Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 05 Focus fuel pump going out?
Old 10-20-2012, 03:20 AM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,393, Level 94
Points: 23,393, Level: 94 Points: 23,393, Level: 94 Points: 23,393, Level: 94
Level Up 5% Completed
Level up: 5% Level up: 5% Level up: 5%
Forum Activity 14%
Activity: 14% Activity: 14% Activity: 14%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Originally Posted by FleaWannaBe
I do plan on replacing the fuel filter first. Even though you say that the actual fuel pump is not bad, just the fuel pump primes, changing the entire fuel pump should fix the problem, correct? Or can I just buy the primes? Really do not have the desire to flash my ecu.
Thanks
Huh?
Buy primes?
Thinking this is over your head and you should bring it in to be diagnosed but,
Primes - When the key is turned to the On position power is sent to the fuel pump, it is on until fuel pressure reaches ~40psi, then turns off. This happens, or should, every time the key is turned form off to the on position.
It's not something you can buy or replace.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
