Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Coil pack diag.
Thread: Coil pack diag.
Old 10-20-2012, 02:30 AM   #3
amc49
Fan#: 96610
Points 6,535, Level 52
Points: 6,535, Level: 52 Points: 6,535, Level: 52 Points: 6,535, Level: 52
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 79%
Activity: 79% Activity: 79% Activity: 79%
Look close for physical small cracks on coil in the plastic, that often is an indicator moisture has gotten into it. Almost all the ones I change have that. Apparently they get hot enough then spit guts out on load.
You can power up the middle contact with 12V and then alternately ground and then break ground to either side terminal with 2 grounded plugs/plug wires to check for spark or no. That would get you to being able to start car probably, but will not prove out missing under load from the cracks. Known good coil swap out is the only test there............
amc49 is offline
