Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 05 Focus fuel pump going out?
Old 10-20-2012, 02:02 AM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,328, Level 93
Points: 23,328, Level: 93 Points: 23,328, Level: 93 Points: 23,328, Level: 93
Level Up 98% Completed
Forum Activity 11%
Activity: 11% Activity: 11% Activity: 11%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Does not sound like the physical fuel pump is bad.
The "noise" is the fuel pump. When you turn the key to "on" the fuel pump primes. This takes a second or two.
If you "start" the car the fuel pump still has to prime before the car will start. It will run on lower fuel pressure, just not well.
IIRC there is a TSB for long crank/hard starts that Ford can do. It may help some. It's an ECU reflash and will cost money. How much I can't say. Might be enough that it may be worth looking into an Xcal and custom tune.
But just to cover bases,
When was the Fuel Filter last replaced?
If you don't know or it's been a while, replace it. It's cheap and relatively easy to do. It also rules out 1 possibility.
Do that first and see if anything changes or improves.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
