Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 focus with sony upgrade retain stock headunit & aftermarket speakrers\amp
Old 10-19-2012, 03:25 PM   #2
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
Points 2,541, Level 30
Points: 2,541, Level: 30 Points: 2,541, Level: 30 Points: 2,541, Level: 30
Level Up 61% Completed
FF Reputation: 8 I Bleed Ford Blue Good Standing Member
You basically have to use the high level outputs coming out of the sony amp, which is located in the trunk or rear hatch area under the spare tire cover in the upper left hand corner of the foam spacer block.
Give this thread a read it will give you a jump start on wire locations
Wiring Guide for the Sony 10 Speaker Amp?
The focus only has one center channel (in the front) and one sub, hence the 10 speakers versus 12 in the fusion, and the wire colors are most likely different.
Most likely you will not have to rip into the dash at all, just the doors and trunk or hatch area.
13 Blue Flame F150 FX4 402A on 20's loaded
13 Frosted Glass Escape Ti 401A loaded
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
