Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Snow Tires Yes or No
Old 10-19-2012, 09:49 AM   #57
CeeBee
Fan#: 101389
What I Drive: 2012 Red Candy Ti 5-Door 5MT
Points 877, Level 15
Points: 877, Level: 15 Points: 877, Level: 15 Points: 877, Level: 15
Level Up 77% Completed
FF Reputation: 1 CeeBee Good Standing Member
Originally Posted by faridk89 View Post
yeah I understand but I found a set of 4 mounted on 5-108 steelies for 280 (Michelin X-Ice Xi2)
If the rims you found are any bigger than 15" in diameter then you'll probably have a tire that has a significantly larger diameter than OEM causing speedo error. For example a 16" diameter wheel with those tires will cause a 6% error
If the wheel is 14" in diameter, you would have a tire that would have minimal speedo error, but it probably wouldn't fit over your front brakes, since the minimum OEM wheel size is 15".
AND, as the poster above mentioned narrower is better for snow/winter tires.
CeeBee is offline
