Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - DDMTuning Cart (HID)
Old 10-18-2012, 09:16 AM   #24
Barrow88
Barrow88's Avatar
Fan#: 91009
What I Drive: 10' Black SES, 02' Boosted ZX3
Points 964, Level 16
Points: 964, Level: 16 Points: 964, Level: 16 Points: 964, Level: 16
Level Up 64% Completed
FF Reputation: 4 Barrow88 Good Standing Member
Hey DarderSauce, Morimoto MiniH1 projectors use a H1 bulb so you need to order a H1 kit not the H13 as the projectors themselves have the hi/low function not the bulbs and I see you were going to get 55w just thought you'd like to know those projectors are not ment to have 55w HIDs they are made for 35W so the 55s could damage the projector bowls. It might be close to the same amount if you just ordered the retrofit kit instead of the projectors from morimoto and HIDs from DDM.
You will probably need the Morimoto relay kit for the projectors it has the hi/low connectors for the projectors.
http://www.theretrofitsource.com/index.php?cPath=28
You might be able to get away using the DDM H13 hi/low harness but the hi/low connectors will be different so you will need to modify it to work (I had the hi/low ddm harness when I had hids in the stock housings so I know the connectors will be different)
http://www.ddmtuning.com/Products/High-Low-Harness
'10 SES
Build Thread:
ZX3
Build Thread: Already Built... For Now
Barrow88 is offline
