Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Anyone upgraded their Sony 10-speaker stereo?
Old 10-17-2012, 11:43 PM   #53
Linchpin
Fan#: 103384
What I Drive: 2012 Platinum White Focus Titanium
FF Reputation: 1 Linchpin Good Standing Member
Smile
Originally Posted by Daytona Coupe View Post
Well, tried disconnecting the center channel. I have mixed feelings about it.
In my opinion:
Pro: got rid of most of the echo-ey nasal sounding midrange I was hearing. This seems to be a byproduct of these frequencies bouncing off of the glass.
Con: seemed to hurt the soundstaging, moved the sound lower and more into the doors (to be expected). Tonal balance might have been slightly better with it connected.
So I'm split on it. As of now, I left it reconnected, and I'm going to continue to look for other solutions. Adding a resistor to reduce the center volume or attempting some type of passive equalization might work. We'll see, I'll report back if I find something that seems to help.
If you have an iPad or iPhone try an app called EQu (available on the app store). You can either use line in (RCA mini) or bluetooth to connect to MFT audio. Launch EQu and select a song (Mary Chapin Carpenter or Steely Dan are well produced). With the song playing try different presets. When you find the one you like you can fine tune the EQ curve with your fingers. A notch (narrow cut) in the mid range will tame the brightness of the center speaker. Close your eyes and enjoy. Sony never sounded so good!
Linchpin is offline
