Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Alternator WOT switch?
Old 10-17-2012, 11:27 PM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,183, Level 93
Points: 23,183, Level: 93 Points: 23,183, Level: 93 Points: 23,183, Level: 93
Level Up 84% Completed
Level up: 84% Level up: 84% Level up: 84%
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Got it solved.
You'll never guess what it was either.
OK. So I replaced the positive battery cable, improved the grounds and checked all the wiring. Same issue, though voltage was more stable. It still cut out WOT high RPM.
For some reason I played with the gauge cluster and ended up finding out somethings wrong with it. I swapped in the cluster from the other car and it works perfect. So the gauge cluster didn't dim anymore. The headlights still did though and logs showed a big voltage drop under the same conditions.
So today I'm going over what I can change in the tune and I come across something for the high speed fan under high load. I never noticed it before.
So I figure WTH, I'll adjust everything up and see what happens. High enough that it shouldn't kick in under heavy load ever.
And now voltage is good across the board. Weird.
I do think the alternator is a bit weak though. But this should prolong it somewhat.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is online now
