Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How-To: Focus MTX-75 Duratec clutch, Phantom Grip, and Poly mount install
Old 10-17-2012, 06:00 PM   #83
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 25,208, Level 95
Points: 25,208, Level: 95 Points: 25,208, Level: 95 Points: 25,208, Level: 95
Level Up 86% Completed
Level up: 86% Level up: 86% Level up: 86%
Forum Activity 100%
FF Reputation: 81 felixthecat Excellent Standing Member
Since you have the cradle out= great time to uupgrade your sway bar= eibach's 22mm.
Originally Posted by aboythatskates View Post
ok well i did the same. for some reason i read somewhere the bearings on the safts had to be re-shimmed
All I did was remove the ring gear from the old diff & attached it to the torsen & then clean the bolts a little & add a little loc tite to each bolt & tighten them & checked again. Put your new trigger wheel on the diff & then press the carrier bearings on the diff. What could be easier? Oh torque the ring gear bolts to 65lbs & criss cross when you tighten them. Clean both sides of the case & use a plastic razor blade= you don't want to nick either side of the case. Grab some rtv & spread it around w/ your finger, bolt it up & then zip it down. Since you have the cradle out great time to upgrade your front sway bar too. I just cleaned & regreased my eibach bar & bushings.
felixthecat is offline
