Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Swapping Audiophile System
Old 10-17-2012, 04:47 PM   #2
FocusHero
Fan#: 100491
What I Drive: 2003 Black Svt
Points 1,137, Level 18
Points: 1,137, Level: 18 Points: 1,137, Level: 18 Points: 1,137, Level: 18
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
FF Reputation: 1 FocusHero Good Standing Member
I believe the stock radio and audio pile have the same wire harness so all you need is the sub harness and you just have to run wires for the sub which is very easy if you have any audio sense at all just find a diagram floating around on here for the amp
svt dohc: eibach spring, k&n intake, magna flow 2.5, light weight flywheel and 69mm throttle body
SVT or die!!!!!
FocusHero is offline
