Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT lightened flywheel Tune
Old 10-16-2012, 10:59 PM   #1
LOADED
LOADED's Avatar
Fan#: 81895
What I Drive: 2003 Sonic Blue SVT Focus
Points 2,224, Level 28
Points: 2,224, Level: 28 Points: 2,224, Level: 28 Points: 2,224, Level: 28
Level Up 50% Completed
FF Reputation: 1 LOADED Good Standing Member
Hey Tom,
I just had a new clutch put in with a light weight flywheel on my SVT focus. its a CM stage3 clutch. Anyway, after the new lightened flywheel from 0-3500RPM my car bogs pretty hard. Could you make a mail order tune for that? My car already has FSWERKS 93 octane RLA6 tune loaded to the computer. At one point my SCT x3 device failed, I lost the stock svt tune, SCT did rebuild my device. can I load your tune to my ecu with out the stock tune?
also my mods are,
SCT x3 FSWERKS RLA6 93 octane tune
CM stage3 clutch W/aluminum Flywheel
FC 65mm Throttle body
FC underdrive pulleys
AEM cold Air Intake {idles rough when cold}
Magnaflow Catback
DE Off Road Pipe
Taylor thunder volt 8.2mm wires
denso iridum plugs
Will your tune solve the bogging from the lightened flywheel?
what would you charge for a mail order tune designed for those mods?
and do I need do I need to return my tune back to stock before i load a different tune?
Thanks,
-Matt.J
2003 Sonic Blue SVT Focus #524
LOADED is offline
