Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Why you should retrofit your lights
Old 10-16-2012, 09:47 PM   #11
Barrow88
Barrow88's Avatar
Fan#: 91009
What I Drive: 10' Black SES, 02' Boosted ZX3
Points 964, Level 16
Points: 964, Level: 16 Points: 964, Level: 16 Points: 964, Level: 16
Level Up 64% Completed
FF Reputation: 4 Barrow88 Good Standing Member
Originally Posted by Baldurs390 View Post
i wanna do projectors in my fogs so bad... was it an easy install?
It wasn't too bad I would say easier to about the same as the headlights, I purchased a second set of aftermarket fogs for the retro as I didnt want to hack up my stockers. I opened them up, enlarged the hole where the h11 bulb would normally go to acomadate the base of the blazers, cut off the 2 mounting tabs on the blazers so that they'd fit with in the fogs, JB Welded them in place, made some L brackets to mount the shrouds (had to trim down part of the aftermarket fogs so they'd sit flush with the projector) and used the factory mounting of the fogs to mount the fog light. The only way to aim them this way is to use washers where they mount to the fog light bracket the factory adjusters wont work because of the way I had to mount the projector. But here is some bad news Blazers are no longer made the manufacture discontinued them, I got lucky as The Retrofit Source had some left that had dust inside of the projector and got them at a discount. Also blazers are also known for the getting hot and the bowls burning but I went with them anyway. Sorry for no pics on how I did it, once i get started on a project I like to just work on it to get it done.
'10 SES
Build Thread:
ZX3
Build Thread: Already Built... For Now
Barrow88 is offline
