Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Whiring/Whining noise..
Old 10-16-2012, 02:49 PM   #3
grayzx35speed's Avatar
Fan#: 94839
What I Drive: 2006 Gray ZX3
FF Reputation: 0 grayzx35speed Newbie
Originally Posted by MegaJoltSVT View Post
So recently I have noticed in my 2002 SVT this whiring/whine noise when I accelerate.. but only when the window is closed and radio off. I assume its from the transmission. Transmission was replaced before I bought the car roughly 40,000 miles ago. I am not sure if the previous owner had replaced gear oil or not.. Do you think I need to change fluids or is it a bigger issue that I need to deal with asap? Or is this normal???
My Duratec makes a whiring sound at high rpms, but thats normal for the vehicle, well mine anyway, at first I thought I may have been throwing a bearing but turns out the heat shield for the fuel pump shakes after 4500 on mine causing a whiring. As for the fluids yes! Change them out whenever you buy a second hand vehicle, assume the previous owner knows nothing about maintenance. Also check oil for metal fragments just to be sure the whiring is mechanical.
North East Honda Killer
OBX Header, Hi flo cat, dremled throttle body/intake manifold, k&n cold air intake, eibach 1.5" springs with Ford Racing gas strutsand Toms tune with PZEV delete and 91 octane
grayzx35speed is offline
