Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - valve seat problems?
Old 10-15-2012, 10:10 PM   #11
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 22,832, Level 93
Points: 22,832, Level: 93 Points: 22,832, Level: 93 Points: 22,832, Level: 93
Level Up 49% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Why did you put the injector cleaner in in the first place?
Just because?
Without knowing anything about the car, I'd say an injector is stuck open or something like that; fuel related.
It could very well be that the cleaner broke something loose that is preventing an injector from closing. That will dump too much fuel. It may be enough the puddle in the intake manifold. During the overlap period of the cams they need to breath back into the intake, if fuel is blocking the path it can backfire; the overlap air is warm.
If this is the case, pull the fuel pump fuse and try to clear any extra fuel this way. It isn't the safest method but so long at your careful it works.
Once the car dies on it's own, try starting it a few more times just to be sure.
Then pull the connectors on the injectors, put the fuel pump fuse back and try to start the car. If it starts or makes a better attempt than previously, odds are an injector is stuck.
My best advice here is the have a shop flush the lines and replace the fuel filter. Then replace all the injectors with known good ones.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
