Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - battery voltage required for starting
Old 10-15-2012, 03:22 PM   #7
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 864, Level 15
Points: 864, Level: 15 Points: 864, Level: 15 Points: 864, Level: 15
Level Up 64% Completed
FF Reputation: 2 BrApple Good Standing Member
Originally Posted by Daytona Coupe View Post
If you have enough power to crank the engine at a reasonable speed (sounds like you do) - then you have enough voltage for the ignition & computer to work. Voltage is not your problem.
That is the thing, when it didn't start it didn't crank as fast as it normally does. However everything electronic worked.
I do feel there maybe something else going on here, I'm going to do some testing of my own on the battery and then take it to the dealer.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is offline
