Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - battery voltage required for starting
Old 10-15-2012, 09:34 AM   #5
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
What I Drive: '01 ZX3, '12 SE Sport
Points 1,806, Level 25
Points: 1,806, Level: 25 Points: 1,806, Level: 25 Points: 1,806, Level: 25
Level Up 6% Completed
FF Reputation: 12 TboneZX3 Great Standing Member
Originally Posted by BrApple View Post
Would a voltage lower then 12.5~12.6, which is normal for a good 12 volt battery effect the ability of the car to start.
Not necessarily, no. As already stated, open-circuit (unloaded) voltage alone is not a good indicator of the battery's charge status.
That is why I am wondering if starting it twice and only letting it run for maybe 5 minutes total would ahve caused a lower then normal charge on the battery and therefore a starting problem.
"Lower than normal"? Yes, probably, but if the battery is good, that type of use wouldn't reduce the charge enough to cause a no-start condition. I could do that 5 times in a row with a good battery and it would still start.
HN #90
Mk3 |╠╬╝|SGM|203a|Moonroof|17" Paint/Mach Whls|K&N 57S-4000 -snorkel|FFE RMM|Steeda STB, RSB|JBR bushings
Mk1|╠╬╝|Pitch Blk|Prem pkg|Moonroof|SVT Snorkel|SVT Susp|Steeda STS|Z-Eng RMM|Magnaflow exh
TboneZX3 is offline
