Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Fog Light Installation - S Model (with Pics)
Old 10-15-2012, 07:57 AM   #51
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 2,534, Level 30
Points: 2,534, Level: 30 Points: 2,534, Level: 30 Points: 2,534, Level: 30
Level Up 56% Completed
FF Reputation: 4 Tiger-Heli Good Standing Member
Originally Posted by brianm View Post
I just have one question. Why not use a stand alone relay harness kit with a small discreet switch like some of the pilot kits. No wire tampering no splicing no worries no voiding warrenties.
Sure, you can do that - essentially, that's pretty much what Chaddz3 (sp?) ended up doing (basically).
As far as why you might not want to:
  • That solution will essentially turn the fog lights on and off with the external switch - not when the headlights are turned on and off (unless you wire the switch inline with the headlights - but that defeats the purposes of your argument).
  • It would be preferable to use the OEM headlight switch rather than having an aftermarket toggle switch in a brand new car - not that it won't work, but it won't look factory.
  • Ford already runs the wiring from the BCM to the front bumper - they just don't have the harness to the fogs or the harness to the switch installed - so you would be having to run your own wiring through the firewall and duplicating unused wiring that was already there.
  • There is wire splicing involved - just not splicing into factory wiring. There is also a connection to the battery so there is somewhat of a warranty concern - although in either case the modification that was done would have to cause an issue for them to deny warranty coverage.
FWIW ...
Tiger-Heli is offline
