Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2000 Ford Focus ZX3 Zetec DOHC Engine Oil Leak
Old 10-14-2012, 11:15 PM   #4
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,396, Level 29
Points: 2,396, Level: 29 Points: 2,396, Level: 29 Points: 2,396, Level: 29
Level Up 64% Completed
Forum Activity 12%
Activity: 12% Activity: 12% Activity: 12%
Buy-Sell-Trade Rating: (3)
The oil filter should come with a circular, thick rubber gasket that fits snugly in a groove. However, the mating surface between that gasket and the oil filter housing should be checked for smoothness.
(I have also seen instances where the old gasket was not removed by mistake (two gaskets stacked on each other) but they tend to leak violently when under running pressure. )
If the oil filter is correctly installed and tightened, have a look at the pressure switch near it (about level with the top of the filter, more towards center of car.)
BC_ZX3 is offline
