Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Normal Idle Vibration
Old 10-14-2012, 09:37 PM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 24,402, Level 95
Points: 24,402, Level: 95 Points: 24,402, Level: 95 Points: 24,402, Level: 95
Level Up 6% Completed
Forum Activity 100%
FF Reputation: 80 felixthecat Excellent Standing Member
Originally Posted by Vegoose View Post
This is a noob question but I can't find an exact answer by searching the forums. I recently purchased an 06 ZX4 as a commuter vehicle and, eventually, for my son to drive. It's been a long time since I've owned 4 cyl vehicle and I'm not sure how much engine vibration at idle is normal.
I can feel a slight vibration in the steering wheel and some in the seat when idling without the A/C running. With the A/C running the engine actually seems to smooth out.>>>> The a/c kicks the motor to a slightly higher rpm.<<<<
I've read on the forums to check for vacuum leaks, possible clean or replace the IAC and/or TPS. Before I do all that, just wondering if I should expect some vibration from the Duratec 2.0?
Yes, its a 4 cyl & thats the way it is. Your going to get vibes thru the S/W. You should see my wheel vibrate w/ bsd & cams at idle. No big deal.
felixthecat is offline
