Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - battery voltage required for starting
Old 10-14-2012, 09:09 PM   #3
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 846, Level 15
Points: 846, Level: 15 Points: 846, Level: 15 Points: 846, Level: 15
Level Up 46% Completed
FF Reputation: 2 BrApple Good Standing Member
Yes a load test is a good idea.
However, you are partly saying what I was getting at. Would a voltage lower then 12.5~12.6, which is normal for a good 12 volt battery effect the ability of the car to start. Again everything else worked correctly. The engine did crank over, it just didn't start. That is why I am wondering if starting it twice and only letting it run for maybe 5 minutes total would ahve caused a lower then normal charge on the battery and therefore a starting problem.
I checked the voltage across the battery while running and it was 15 volts. So the alternator is charging correctly. Also it hasn't had an issue starting at all for the rest of today.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is online now
