Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 02 Focus DOHC Hot Start
Old 10-14-2012, 04:44 PM   #10
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,461, Level 100
Points: 32,461, Level: 100 Points: 32,461, Level: 100 Points: 32,461, Level: 100
Forum Activity 46%
Activity: 46% Activity: 46% Activity: 46%
BTW... did you check your grounding? We had another FF with a similar problem that was due to grounding. There should be one big wire off the negative battery terminal that goes to the engine block. There should be a copper shoelace that goes from the engine to the chassis, and 2 small ground wires that go from the negative battery terminal to the chassis and the wiring harness.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
