Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2010 focus se sedan: problem with door locks
Old 10-14-2012, 12:28 PM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,612, Level 100
Points: 32,612, Level: 100 Points: 32,612, Level: 100 Points: 32,612, Level: 100
Forum Activity 46%
Activity: 46% Activity: 46% Activity: 46%
oooooh, that's different entirely. Is it just the driver's side or both sides?
oh, lack of reading comprehension there, sorry. Yes, you have a problem, most likely in the driver's side switch. I recommend removing the driver's side switch, and checking it. Most likely you lost a wire there. It could be anywhere, but I'd check there first because the driver's side is what takes the most abuse, and usually problems are at the switches not the wiring in between. Now if you've recently had an electronics upgrade- like GPS hardwired, or new radio, that might be a good place to look for clues.
I would pull on the wires going into the connector, and also make sure that there is not something obvious wrong with the switch itself.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
