Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Mazda3-5 MS3 MotorMounts Fit 2012 Focus
Old 10-14-2012, 12:22 PM   #348
mustang0
mustang0's Avatar
Fan#: 96079
What I Drive: 2012 Blue Candy SE HB Sport Package
Points 855, Level 15
Points: 855, Level: 15 Points: 855, Level: 15 Points: 855, Level: 15
Level Up 55% Completed
Level up: 55% Level up: 55% Level up: 55%
FF Reputation: 1 mustang0 Good Standing Member
Originally Posted by amoosenamedhank View Post
Been running my MS3 RMM with CS inserst for about 5,000 miles now. There is definitely an improvement over stock, however, I still feel like there is a decent amount of drivetrain slop in this car.
I mentioned this in another thread... but on my last car (MS6) when I removed the RMM, it took another guy and all of his strength to move the engine into place to line up the bolt. However, when I removed the RMM from the focus, the damn engine swung back and forth like a pendulum.
This leads me to believe more success can be hand with the other two engine mounts. Mostly in the TMM.... my concern is obviously vibration.
So I thought of another approach. I believe it was focus boy who reported an un-desirable amount of vibrations just from a 70 duro RMM. I'm fairly certain the main culprit behind this is the ~650 idle rpms. Once tuning is available for this platform, we will be able to bump our idle rpms to 800. This will reduce a substantial amount of vibes during idle and I think will allow us to be able to run a higher duro mount with out the side effects of vibes.
This might actually be a better solution over replacing the TMM at this time. I have a few locals with MS3 with aftermarket mounts. I might see if I can get one of them let me try their mount.
If I can get my hands on one, I'll run a little test. Since the update, if you put the car in gear with out your foot on the brake, the rpms will raise to around 850. This will give me a pretty good idea of what the mount would feel like if we were able to raise the idle with a tuning solution.
I totally agree that this car needs more than the MS3. When you get on it really hard you definitely can feel some looseness still. I think I'm going to try taking the stock unit and filling it in solid with high durometer rubber compound and see if that makes a difference.
65 Racestang 2012 Focus SE HB Sport Pac 5 speed man. NewMission Cold Air, Custom 3" Magnaflow exhaust, Steeda Rear Sway Bar, Eibach sportline springs, Steeda STS, Axis wheels, Blox shift knob, Focus elecrtic RMM, Injected 93 Tune V1 176HP 152Torque
mustang0 is offline
