Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - way to charge phone and have phone outside of center counseL?
Old 10-12-2012, 09:38 PM   #4
hotleadsingerguy
hotleadsingerguy's Avatar
Fan#: 86687
What I Drive: 2012 Black Titanium 5-Door
FF Reputation: 5 hotleadsingerguy Good Standing Member
Originally Posted by lddavis View Post
In the 2012's (I've mostly looked at the ST) there is a groove in the front side of the center console box that allows cables out.
You probably do want a notch from the top, rather than a hole, because the hole would have to be big enough for the connectors, much wider than the cable itself.
Actually that slot isn't for a cable. That slot is for the lid to center and to keep the hinge safe (to keep it centered).
When you close the lid a plastic "tooth" drops down into that groove and goes all the way to the bottom. The better part is the corners of the lid don't close tightly, so I just leave the cable sitting on the corner when I close the lid.
hotleadsingerguy is offline
