Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Yellow ! Star pattern light
Old 10-12-2012, 06:48 PM   #4
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 176, Level 3
Points: 176, Level: 3 Points: 176, Level: 3 Points: 176, Level: 3
Level Up 52% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
Originally Posted by bumble21 View Post
I will try replacing it tomorrow. Is it the same for all the 00-04 focus' like most other parts? Will this cure the problem or just one? I just found it odd that something electric could cause a performance loss like that
This is will only fix the three lower speeds of the blower motor. For the flickering lights check all your main power connections. The connections on the battery, alternator, grounds, ect. Check visually and for tightness and for corrosion.
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
