Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - need help
Thread: need help
Old 10-12-2012, 04:53 PM   #5
rangerbay
Fan#: 76247
What I Drive: 2001 white zts,2001 white wagon,
Points 217, Level 4
Points: 217, Level: 4 Points: 217, Level: 4 Points: 217, Level: 4
Level Up 34% Completed
FF Reputation: 2 rangerbay Good Standing Member
Turn the engine on, then barely pull one plug wire off the coil pack and keep it right at the tip of coil. Spark should jump the the plug wire. Do that for all 4. If you're getting spark there, then check the spark at the spark plug, same way. If you have spark at the coil, but not at the plug= bad plug wire.
Did you check the hoses? That is the first thing I'd check.
Bill
rangerbay is offline
