Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Corner Indicator (Housings?) Swap
Old 10-12-2012, 02:15 PM   #4
04ZTSJelf
04ZTSJelf's Avatar
Fan#: 319497
What I Drive: Mk3
Points 3,831, Level 39
Points: 3,831, Level: 39 Points: 3,831, Level: 39 Points: 3,831, Level: 39
Level Up 21% Completed
Level up: 21% Level up: 21% Level up: 21%
Forum Activity 6%
FF Reputation: 7 04ZTSJelf Good Standing Member
Originally Posted by Zx3YTG View Post
I just did this with smoke side markers. Same car. Remove the screw in the wheel well holding the bottom corner of the bumper cover and you should be able to pull it out enough to get a wrench up there (I used a ratchet wrench). The space isn't much though but the bolts holding the posts come off in a few turns. Do the passenger side first so you have an idea of what you're feeling around for on the driver side because you'll basically be doing it blind. Took about 5 minutes.
Thanks, I will try this. It seems like the easiest way of the options I have read so I will try it before I have to start removing things, haha. Also, on a slighty related note, I replaced the bulbs in my headlights after fiddling with it blindly for an hour but the passenger side light points up slightly higher than the driver side. It was like this before and after I replaced the bulbs. I tried adjusting it a little but it had no effect. Is it supposed to be like this?
04ZTSJelf is offline
