Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - need help
Thread: need help
Old 10-11-2012, 09:07 PM   #2
rangerbay
Fan#: 76247
What I Drive: 2001 white zts,2001 white wagon,
Points 217, Level 4
Points: 217, Level: 4 Points: 217, Level: 4 Points: 217, Level: 4
Level Up 34% Completed
FF Reputation: 2 rangerbay Good Standing Member
Check you hoses for crimps or leaks. Then check to make sure you're getting spark to all cylinders.
I had a crankcase vent tube crimp causing a bad idle. It was crimped at the rear of the motor, you had to follow the rubber tube to the back to find it. It starts out as ametal tube from the crancase, drivers side front, and goes into a rubber tube under the thermostat housing. Follow it from there. That could be your problem.
Bill
rangerbay is offline
