Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Yellow ! Star pattern light
Old 10-11-2012, 09:18 PM   #1
Fan#: 95826
What I Drive: 2001, Black&Yellow, ZX3
FF Reputation: 1 bumble21 Good Standing Member
I have a 2001 ford focus zx3 with 175k on the odo. My blower motor only works on the 4th setting. I turned the blower motor on for heat or ac doesn't matter which same result. I was going about 55 in 4th gear and it felt like the front end of my car just dipped down like an all of a sudden loss of power. Right when I turned the blower on the light came on for about 5 seconds and shut off. This happens whenever at high rpm 3k + or so. If at idle it will not happen or jut normal cruising. At night even at normal cruising speeds my lights do flicker. I'm not sure why the light came on or what could be wrong any help would be much appreciated. Thank you in advance for your responses
bumble21 is offline
