Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Question about installing HIDs.
Old 10-11-2012, 06:39 PM   #3
Fan#: 83240
What I Drive: 2000 SE Sedan
FF Reputation: 1 Ndstrctbl Good Standing Member
with the ddm h4 hid kit it comes with a wiring harness assuming you checked "yes" in the high/low section when you ordered it. the harness will have a positive and negative wire, connect them to the battery. run one side of the harness to your drivers side headlight and the other to the passenger side. the passenger side will have a ground wire, ground it anywhere you want as long as its a good ground(sand all the paint away and make it secure) on the drivers side there will be a an h4 socket on the harness, plug your stock H4 connector into that. the harness will have 9006 connectors for the ballast, plug them into your ballasts, then connect the hid bulbs to the ballast then put them into your housings. you should be done at this point.
Ndstrctbl is offline
